Field Read Only Field: Locked Flag
Use this user property to set only the specified field to read-only mode. The value of the user property determines if the specified field is set to read-only mode.
Property Description/Value
Value
Calc Locked Flag Read Only
Parent Object Type
TNT History Opportunity business component
Usage
If this user property is set, then the field name after the colon (:) in the user property name is read only. The value of the user property determines if this field is read only.
