Ignore Case Sensitivity
This user property is used to control the case sensitivity for comparing function space strings and the string entered in the Go To field.
Ignore Case Sensitivity | Description |
Value |
Y |
Parent Object Type |
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary |
Usage |
This user property is used to control the case sensitivity for comparing function space strings and the string entered in the Go To field. |
