Item Color Toggle Activate Fields
Use this user property to activate fields that are used in the function booking color scheme based on the Item Color Toggle Field user property value.
Item Color Toggle Activate Fields Description
Value
Function Status;Quote Status
Parent Object Type
TNT SHM Function Space Diary Total Availability Applet, TNT SHM Compact Function Space Diary, and TNT SHM Function Space Diary applets
Usage
This user property is used to activate all the fields that could be returned as the value of the Item Color Toggle Field user property.
