Named Method 11
Use this user property to update the Day number (#) field and Date field for the associated subfunctions when the same fields for a function change.
Named Method 11 Description
Value
"Update Sub Function", "INVOKESVC", "TNT SHM Function", "TNT SHM Day Number", "UpdateSubFunction"
Parent Object Type
TNT SHM Function business component
Usage
Updates the Day number (#) field and Date field for the associated subfunctions when the same fields for a function change. This user property works with the On Field Update Invoke 19 user property.
