Named Method 22
Use this user property to call an internal service method to set the Split flag value for the parent menu when TNT Split Qty Flag field of an associated child Menu Item is updated.
Property Description/Value
Value
"SetParentSplitFlag", "INVOKEALL", "TNT SHM Order Item", "SetSplitValue"
Parent Object Type
TNT SHM Order Item business component
Usage
Calls an internal service method to set the appropriate value for the Split Menu Flag of the parent menu, when the TNT Split Qty Flag field of an associated child menu item is updated. This user property works with the On Field Update Invoke user property.
