Process of Setting Up Sleeping Rooms
You can define sleeping rooms for a property. One or more generic sleeping room types can be mapped to one or more property-specific sleeping room types. You can assign a percentage to each mapped property-specific sleeping room type to specify how many rooms of each type to reserve.
Additionally, one or more property-specific sleeping room types can be mapped to a run of house (ROH) sleeping room type. For more information about ROH sleeping rooms, see About Run of House Room Types.
For use case examples of sleeping room mapping, see Scenarios for Mapping Sleeping Rooms.
This topic lists the procedures that administrators typically perform to set up sleeping rooms with Siebel Hospitality. Your company might follow a different process according to its business requirements.
To set up sleeping rooms, perform the following tasks:
  1. Creating Sleeping Room Records
  2. Mapping a Generic Room Type to Property-Specific Room Types
  3. Mapping a Run of House Room Type to Property-Specific Room Types
  4. Setting User Properties for Sleeping Room Mapping
This task is a step in Roadmap for Setting Up Function Spaces, Sleeping Rooms, and Suites.
