Reviewing Charge Codes for a Revenue Category
After setting up all the charge codes, perform the following steps to view the charge code associations to each category using the Revenue Category Administration view.
This task is a step in Administering Charge Codes.
To review charge codes for a revenue category
  1. Navigate to the Revenue Category Administration screen, then the Category Admin List view.
  2. In the Category Admin list, query for and select the required revenue parent category, and then click the link in the Name field.
  3. Scroll down, and select the required revenue category in the Revenue Categories list.
  4. Scroll down, and click the Charge Codes tab.
    The Charge Codes list displays all the charge codes associated with the revenue category record.
