Setting Up Guest Conveniences
Guest conveniences are amenities that are in close proximity to the property, and that might be useful to guests during their stay at the property. Guest conveniences can include local airports, restaurants, booking centers, attractions, and other local companies.
Before guest conveniences can be associated with a property record, you must add the guest conveniences to the Siebel Hospitality database. The following procedure details how to set up guest conveniences in Siebel Hospitality.
For more information about associating guest conveniences with a property record, see Defining the Neighborhood Characteristics of a Property.
This task is a step in Roadmap for Setting Up Hospitality Properties.
To set up guest conveniences
Navigate to the Guest Conveniences Administration screen, then the Guest Conveniences view.
In the Guest Conveniences list, create a new record, complete the fields, and save the record.
The following table describes some of the fields.
Field Comments Name
Name of the guest convenience.
Type
Type of convenience, either Airport, Booking Center, Restaurants, Local Companies, or Attractions.
Address1
Street address of the guest convenience.
Address2
Remainder of the street address of the guest convenience.
City
Name of the city in which the guest convenience is located.
State
Name of the state in which the guest convenience is located.
Zip/Postal Code
ZIP or postal code of the guest convenience.
Country
Name of the country in which the guest convenience is located.
Description
Description of the guest convenience.
Driving Directions
Driving directions from the property to the guest convenience.
