Setting Up Indivisible Specific Space Suites
The process of creating indivisible specific space suites is similar to the process for setting up indivisible specific spaces.
This task is a step in Process of Setting Up Suites.
To set up an indivisible specific space suite
Navigate to the Property Administration screen, then the Properties view.
In the Properties list, query for the required property record.
Click the link in the Property Name field and then click the Specific Space view tab.
In the Specific Space list, create a new record and select the Suite check box.
Complete the other fields, as required.
For more information about the fields on the Property Administration screen, Specific Space view, see Creating Indivisible Specific Spaces.
