Setting Up Suite Administration
You can specify information for suites such as check-in times, check-out times, and revenue routing. Check-in and check-out information is used when booking suites as sleeping rooms.
This task is a step in Process of Setting Up Suites.
To set up suite administration
Navigate to the Property Administration screen, then the Properties view.
In the Properties list, query for the required property record.
Click the link in the Property Name field, and then click the Suite Administration view tab.
In the Suite Administration form, complete the fields as required.
The following table describes some of the fields.
Field Comments Check-in Time
The time when the guests can check in to the hotel when the suite is used as a sleeping room.
Check-out Time
The time when the guests have to check out of the hotel after sleeping in a suite.
Suite Room Rental
Select to count the suite rental as sleeping room revenue. Clear to count the suite rental as function space revenue.
