Sort Specification Field
Use this user property to sort the subfunctions in Create Agenda Sub Function pop-up applet.
Sort Specification Field Description
Value
Start
Parent Object Type
TNT SHM Function business component
Usage
This user property is used to sort the functions in the Opportunities screen, Function Agenda view. This user property is used only if the ViewMode Sort:3 user property is not available. To sort the functions on a different field, modify the value of this user property with that field name.
