TNT SHM Number of Nights Field
Use this user property to set the correct value of the Num Nights Duration field on a change of arrival date (that is, a change to the value of the Calculated Arrival Date field) or a change to the closed date (that is, a change to the value of the Hospitality Close Date field).
Property Description/Value
Value
Num Nights Duration
Parent Object Type
Opportunity Home Add Virtual business component
Usage
The value of this user property is a business component field. When the Calculated Arrival Date field or the Hospitality Close Date field is updated, a new value for the Num Nights Duration field is calculated and set by way of C++ code.
