Units Per Segment Major
This user property is used to specify the number of units per segment on the major axis.
Property Description/Value
Parent Object Type
TNT SHM Gantt AX Date Time Interval PopUp VBC
Value: 1;7;2;1;4;1;8;0.5;16;0.25;32; 28;64;1;128;1;256;7
Parent Object Type
TNT SHM Inventory Gantt AX Date Time Interval For Order PopUp VBC
Value: 1;7;2;1;4;1;8;1;16;1;32;28
Parent Object Type
TNT SHM Inventory Gantt AX Date Time Interval PopUp VBC
Usage
Use to specify the number of units per segment on the major axis.
