View Aspect: TNT SHM Event Check Line Items More Info View
Use this user property to set the event checks with the specified Status fields as read-only records.
Property Description/Value
Value
TNT_EVENT_CHECK_STATUS
Parent Object Type
SHM Invoice Form Applet applet
Usage
Sets the event checks with a Status field of Posted or Voided as read-only records. When the user selects these event checks, the TNT SHM Event Check Line Items More Info View becomes a read-only view. When an event check is a read-only record, any associated function or line item records are also read-only records.
