Viewing Assets Associated with a Product
A user can view the assets associated with a specific hospitality product using the Function Line Items Assets view. You can view the assets for both property-specific products and products from other properties.
This task is a step in Process of Booking Hospitality Assets.
To view assets associated with a product
  1. Navigate to the Functions screen, then the Function List view.
  2. In the Functions list, query for and select the required function.
  3. Click the link in the Function Name field.
  4. In the Line Items list, select the line item, and then click the Assets view tab to view the assets for a product at a particular property.
    The following table describes some of the fields in the asset record.
    Field Comments
    Asset #
    The asset identifier
    Product
    The product with which the asset is associated
    Status
    The asset inventory status
    Installed
    The date the asset was installed
    Serial #
    The asset serial number
