Setting Up Redemption Packages as Bundled Products
To set up redemption products as a bundled product, complete the steps in the following procedure.
To set up a redemption products as a bundle product
Create new redemption products in the Loyalty Administration – Products tab as described in Example of Setting Up a Redemption Product and Base Price List for a Redemption Package.
For more information on creating a product, see Siebel Product Administration Guide.
Associate the redemption product with a partner.
The redemption products are associated to the partner in the Partner Product Offering view in the Loyalty Partners tab. You can select the program for which this product is being offered by the partner, the effective dates within which the product is available for redemption to the members, the offer type as redemption, and the pricing type: Points, Points by Distance, or Points by Zone.
Note: For a bundled product, the pricing type is typically Points.Create a bundle product.
Define one more product with the Structure Type as Bundle, and associate the products defined in Example of Setting Up a Redemption Product and Base Price List for a Redemption Package. If a constituent product type of a bundled product is electronic voucher, then Loyalty issues a voucher for that product when redeeming the bundled product.
Define the redemption package base price list for the bundle product.
Based on the partner product offerings setup for the individual products within the bundle product, you can choose one partner for one price line in the Bundle Product-Points view.
