Specifying Objects Processed by the Siebel Loyalty Engine
You can specify which objects the Siebel Loyalty Engine processes by using the parameter LOYEngineQueueObjects.
The following table lists the types of objects that the Siebel Loyalty Engine processes.
| Type | Business Object and Primary Business Component | Description |
Transaction |
LOY Transaction Processor LOY Engine Transaction |
Processes the transaction for any qualified promotions. Processed against the active promotions in the program. |
Tier |
LOY Tier Processor LOY Engine Member Tier |
Processes the member tiers for change such as Upgrade, Downgrade. Processed only against one promotion of that tier. |
Bucket |
LOY Promotion Bucket Processor LOY Promotion Bucket |
Processes the Promotion Bucket to check whether it has met all the criteria of a complex promotion. Processed only against the promotion in question. |
Accrual |
LOY Accrual Expiration Processor LOY Member Accrual Item |
Processes the accruals that have expired and deducts the points from the member’s balance. There are no promotions involved and only redemptions are created for all expired accruals and member balances are deducted accordingly. |
Document |
LOY Statement LOY Statement |
Processes the statements with an In Progress status and generates a document and sets the status to Completed. The file name points to the generated document. |
