Enabling System Data Expressions for Required Columns
Several of the Campaign Contact columns required for the campaign load format must be populated with values that are determined by the list generation process at run time. To accomplish this, you set up the Campaign Contact columns to use system data expressions. The following procedure describes this task.
To enable system data expressions for required columns
Click the properties button on the Campaign Contact column.
In the dialog box, first click the Custom Headings check box.
This makes sure the table and column name are not changed when you modify the formula in the next step.
- Clear the current formula from the Column Formula box.
Place your cursor in the Column Formula box, then click the Available System Data link.
Select the appropriate system data expression from the values in the following table.
Column Corresponding System Data Expression Campaign Id
Campaign Id
Load Number
Load Number
Scalability Batch Number
Email Batch Number
Segment Id
Segment Id
Token Number
Token Number
Treatment Id
Treatment Id
The expression is added to the formula. For example, the Campaign ID column would show the following formula:
@{campaignID}{0}Note: If you get an error message in the Formula dialog box, then ignore the error.Click OK.
