Setting System Preferences to Enable Contact List Import Using PL/SQL
Use the following procedure to set system preferences.
To set the system preferences
- Navigate to Administration - Application, then System Preferences, and query for the MktgEnableDBImport and MktgIsDBOracle system preferences.
- Make sure that the System Preference value is set to Y for both system preferences. If it is not, set the value to Y and log into the Siebel Marketing application again.
