EnableExceptions Method for an Application
The EnableExceptions method enables or disables native Component Object Model (COM) error handling. This method does not return any information.
Format
Application.EnableExceptions(bEnable)
The following table describes the arguments for the EnableExceptions method.
| Argument | Description |
bEnable |
You can one of the following values:
Usage
Setting the argument to TRUE enables native error handling. This allows Siebel CRM to intercept and display the exception ID and description. Native COM error handling is disabled by default.
Used With
COM Data Control, Mobile Web Client Automation Server
Example of Using the EnableExceptions Method with Siebel ActiveX Data Control
The native Visual Basic script in this example does the following work:
Uses the Siebel ActiveX Data Control to connect to the Siebel application and to create an instance of a business object.
Prompts the user to use or not use the native error handling.
If the user answers yes, and if the script encounters an error, then it issues the error immediately.
If the user answers no, then the script suppresses errors.
You can detect errors only with the GetLastErrCode method.
The following code is an example of using the EnableExceptions method with Siebel ActiveX Data Control:
Dim SiebelApplication As SiebelDataControl
Dim errCode As Integer
Dim wrongBO As SiebelBusObject
Dim nativeHandle As String
Set SiebelApplication = CreateObject("SiebelDataControl.SiebelDataControl.1")
' Login to Siebel
SiebelApplication_first.Login "host=""Siebel.tcpip.none.none://virtual ip:port/
enterprise/object manager""", "user id", "password"
nativeHandle = InputBox("Use native error handling?", "", "Yes")
If nativeHandle = "Yes" Then
SiebelApplication.EnableExceptions (True)
Else
SiebelApplication.EnableExceptions (False)
End If
Set wrongBO = SiebelApplication.GetBusObject("No Such One") 'intended to create an
error at this line by instantiating a nonexisting Business Object
errCode = SiebelApplication.GetLastErrCode()
If errCode <> 0 Then 'if native error handle is disabled, this block detects it
ErrText = SiebelApplication.GetLastErrText
MsgBox ErrText
Exit Sub
End If
Example of Using the EnableExceptions Method with Siebel Mobile Automation Server
The script in this example performs the same work that is described in the example of using the EnableExceptions method with Siebel ActiveX Data Control earlier in this topic, except that the script in this example uses the Siebel Mobile Automation Server:
Dim SiebelApp As SiebelWebApplication
Set SiebelApp = CreateObject("TWSiebel.SiebelWebApplication.1")
nativeHandle = InputBox("Use native error handle?", "", "Yes")
SiebelApp.EnableExceptions (True)
Else
SiebelApp.EnableExceptions (False)
End If
Set wrongBO = SiebelApp.GetBusObject("No Such One") 'intended to create an error at
errCode = SiebelApp.GetLastErrCode()
ErrText = SiebelApp.GetLastErrText
MsgBox ErrText
Exit Sub
End If
