Formats for Siebel VB
If there is a return value, then use the following format:
returnValue = ObjectReference.MethodName(arg1, arg2, ..., argn)
If there are no arguments, then use the following format:
If there is no return value, then use the following format:
ObjectReference.MethodName arg1, arg2, ..., argn
The following examples use Siebel VB:
acctName = acctBC.GetFieldValue("Name")
acctBC.SetViewMode AllView
