LoadObjects Method for an Application
The LoadObjects method starts the COM Data Server. This method must be the first call to the COM Data Server. This method returns the following information:
If the COM Data Server starts successfully, then the LoadObjects method returns nothing.
If the COM Data Server does not start successfully, then the LoadObjects method returns an error.
Format
Application.LoadObjects(absoluteCFGfileName)
The following table describes the arguments for the LoadObjects method.
| Argument | Description |
absoluteCFGfileName |
The path and name of the Siebel application configuration (CFG) file to open. For example: As an option, to identify the data source you can append the CFG file string with the data source, separated by a comma. For example: If you do not specify the data source, then the LoadObjects method assumes the data source is local. |
Usage
Prior to calling the LoadObjects method,
you must modify the current folder to the Siebel\bin folder.
If you use the COM Data Server, then the COM client cannot create multiple connections to the COM Server. For example, a second attempt to call the LoadObjects method causes an error message that is similar to the following:
The object definition manager has already been initialized.You must restart the COM client before you can make another successful connection. Use COM Data Control instead.
Used With
COM Data Server
Examples
The following example uses COM Data Server:
Private Sub LoadConfig_Click()
Dim errCode As Integer
LoadConfig.Enabled = False
SiebelApplication.LoadObjects "C:\Siebel\8.1\Client_2\BIN\ENU\uagent.cfg", _
errCode
If errCode = 0 Then
ConfigOK = 1
End If
Status.Text = SiebelApplication.GetLastErrText
End Sub
