AddChild Method for a Property Set |
Adds child property sets to a property set. |
Dim oPropSet as SiebelPropertySet
Dim iIndex as Integer
iIndex
= oPropSet.AddChild(childObject as Property Set)
Copy Method for a Property Set |
Returns a copy of a property set. |
Dim oPropSet1 as SiebelPropertySet
Dim oPropSet2 as SiebelPropertySet
oPropSet2 = oPropSet1.Copy()
GetChild Method for a Property Set |
Returns a child property set of a property
set. |
oPropSet1 = oPropSet.GetChild(index as
Integer)
GetChildCount Method for a Property Set |
Returns the number of child property sets
that exist for a parent property set. |
Dim iCount as Integer
iCount
= oPropSet.GetChildCount()
GetFirstProperty Method for a Property Set |
Returns the name of the first property in
a property set. |
Dim sPropName as String
sPropName
= oPropSet.GetFirstProperty()
GetNextProperty Method for a Property Set |
Returns the name of the next property in
a property set. |
sPropName
= oPropSet.GetNextProperty()
GetProperty Method for a Property Set |
Returns the value of a property. |
Dim sPropVal as String
sPropVal
= oPropSet.GetProperty(propName as String)
GetPropertyCount Method for a Property Set |
Returns the number of properties that exist
in the current level in the hierarchy. |
Dim count as Long
count = oPropSet.GetPropertyCount
GetType Method for a Property Set |
Returns the value of the type attribute of
a property set. |
Dim sTypeVal as String
sTypeVal
= oPropSet.GetType()
GetValue Method for a Property Set |
Returns the value of the value attribute
Dim sValVal as String
sValVal
= oPropSet.GetValue()
InsertChildAt Method for a Property Set |
Inserts a child property set in a parent
property set at a specific location. |
oPropSet.InsertChildAt(childObject as SiebelPropertySet,
index as Long)
PropertyExists Method for a Property Set |
Returns a Boolean value that indicates if
the property that the argument identifies exists. |
Dim oPropSet as Property Set
Dim propExists as Boolean
propExists
= oPropSet.PropertyExists(propName as String)
RemoveChild Method for a Property Set |
Removes a child property set from a parent
property set. |
oPropSet.RemoveChild(index as Long)
RemoveProperty Method for a Property Set |
Removes a property from a property set. |
oPropSet.RemoveProperty(propName as String)
Reset Method for a Property Set |
Removes every property and child property
set from a property set. |
Dim oPropSet as SiebelPropertySetoPropSet.Reset()
SetProperty Method for a Property Set |
Sets a value in the property of a property
set. |
oPropSet.SetProperty(propName as
String, propValue as String)
SetType Method for a Property Set |
Sets the value for the type attribute of
a property set. |
oPropSet.SetType(value as String)
SetValue Method for a Property Set |
Sets the value for the value attribute of
a property set. |
oPropSet.SetValue(value as String)
