About Adding Products to the Shopping Cart in Siebel Open UI Catalog Browse View
The user can add products using several applets.
The Quote Catalog Product List Applet - Add to Cart Tree Applet
This applet provides three distinct user experiences, so the user can choose whichever they prefer to add products to the Shopping Cart from the Catalog.
The renderer for this applet is responsible for displaying the accessible products using one of the three modes by default. To customize the applet, use the manifest administration functionality to reference a new renderer or a new model for the drop-down. For more information, see Configuring Siebel Open UI
To switch between Compact, List, and Detail displays, click the following buttons:
Compact Display. Displays the products as Compact Tiles.
If no eligibility or compatibility rule exists for a product, the tile includes only the pricing details for the product. If an eligibility or compatibility rule exists for a product, the tile includes two separate sections, one describing the pricing details and the other describing the rule violation.
From the pricing details section, the user can:
change the quantity.
click the edit promotion or customize product icon to configure the promotion or product and save it to the Cart.
click the Shopping Cart icon to add the product to the Cart.
List Display. Displays the products in a grid layout. The user can:
Click the Customize and Edit Promotion buttons to modify products and promotions. These buttons become active or inactive as the user select products.
Click the Add Item button used to add the selected button to the Shopping Cart.
Detail Display. Display product details in an expanded tile, which is similar to the compact tiles but has more room for descriptive text.
Use the arrow buttons to navigate through products.
