Activating Workflows for Order Management
Some order management functionality is based on Siebel Workflows. You must activate these workflows before using the product. For information about activating workflows, see Siebel Business Process Framework: Workflow Guide.
Activate the workflows for the other order management functionality that you are using, as listed in the following table. For example, if you are using Siebel eSales, then activate the workflows for eSales.
Order Management Functionality Where to Find Workflows
Order Management Interface
Workflow and Method Reference for Order Management Interface.
Pricing
Technical reference section of Siebel Pricing Administration Guide.
Product Promotions
Product promotions section of Siebel Pricing Administration Guide.
Integration of Quotes and Orders with Back-Office Applications
Activating Workflows for Integration of Quotes and Orders.
Configurator
Configurator Workflow reference in Siebel Product Administration Guide.
Asset-Based Ordering
Workflow Reference for Employee Asset-Based Ordering.
Eligibility/Compatibility
Eligibility and Compatibility technical reference section of Siebel Product Administration Guide.
Recommendations
Product recommendations technical reference section of Siebel Product Administration Guide.
Siebel eSales
Workflow reference section of Siebel eSales Administration Guide.
Compound Product Validation
Compound product validation section of Siebel Product Administration Guide.
Third-Party Purchase Order Credit Checking Applications
Activating the Workflows for Purchase Order Credit Checking Applications.
Application Deployment Manager
See Siebel Application Deployment Manager Guide.
