Defining Required Fields in Codepage Conversion
You can define which fields that are passed to Taxware are required and whether a field is required for WorldTax, Sales/Use, or both applications.
To define required fields in codepage conversion
  1. In Siebel Tools, from the View menu, select Options.
  2. In the Development Tools Options dialog box, select Object Explorer.
  3. Move Integration Object to the far pane of the dialog box and click OK.
  4. Select the integration object Tax Integration (Taxware Input).
  5. Select Integration Component Field from the Object Explorer.
  6. To make a field required, check the External Required column.
  7. To make a field required for:
    • Both WorldTax and Sales/User, leave the External DataType as String.
    • WorldTax only, change the External DataType to StringWT.
    • Sales/User only, change the External DataType to StringSU.
