Removing a Product from a Catalog and Category
To remove a product from a catalog and category in both the Siebel application and ATG Web Commerce, set the effective end date in the Category view for the product, and then create a Web content export job to export the change to ATG Web Commerce.
  1. Navigate to the Administration - Product screen, then the Products view.
  2. Select the product that you want.
  3. Click the Category tab.
  4. In the categories list, for all categories that you want, enter a value in the Effective End Date field that is before the current date.
  5. To verify your work:
    1. Navigate to the Administration - Catalog
    2. In the Catalogs list, click the Name field of the catalog that contains the category that you removed the product from.
    3. In the Categories list, select the category that you removed the product from.
    4. Click the Products tab, and confirm that the Product is no longer in this category.
  6. Click Update Commerce App.
