Split Method
The Split method splits an input row set into two output row sets by evaluating a condition for each row.
Arguments
Input Argument Description
Context
Optional. Property set of variables shared across all rows.
Row Set
The set of rows to process.
Condition
A Boolean expression that references {Context} and {Row} field values.
On True Row Set
The row set to which rows are moved if Condition evaluates to True.
Example
The following figure shows an example of arguments for a PSP procedure step named Inclusive Eligibility, which uses the Split method.
Example of Arguments for Split Method. This image shows the following Input Arguments (Input Argument, Type, Property Name, Value): Condition, On True Row Set, and Row Set.
