Running Reports
While you are in a view, click Reports in the toolbar to see a list of the available preconfigured reports for the data in that view. The list specifies which reports are available as Oracle Business Intelligence Publisher reports. From the list you can access individual reports. You can run all the reports in the same way.
To run the price lists report
  1. Navigate to the screen and view from which you access the report, as specified in the report’s description.
  2. In the application-level menu, click the Reports icon and select the appropriate report.
  3. In the Reports dialog box, select a report format from the drop-down menu and click Submit.
    The selected report appears in the format specified.
  4. You can print a copy of the report.
