Setting Up Base Pricing for Products with Components
Use the following procedure to set up base pricing for products with components.
To set up base pricing for products with components
Display the components of the product with components in the Pricing Designer, as described in Viewing a Product’s Components in the Pricing Designer.
Define relationship-based pricing adjustments, if they are needed, as described in Viewing and Changing the Reference Price.
In the Price List Item form, go to the List Price field and enter the base price.
In the Pricing Designer list, select the components. In the Adjustments list, enter price adjustments for each component.
If you are using the alternative method of setting up base pricing, then enter the necessary price overrides for default components.
