Available Siebel Configurator APIs
Three main groups of APIs are used for accessing Siebel Product Configurator:
  • Group 1: UI
    • CPRUI Service API as Siebel Web Template items.
    • DOM API within the browser inherent in JavaScript and HTML.
  • Group 2: Model
    • Scripts that execute in the context of the current session and are implemented as part of the configuration model in the Scripts view.
  • Group 3: Instance
    • This API is for using Siebel Product Configurator or for manipulating the configuration session from a place other than the Siebel Product Configurator runtime UI.
    • The Remote Complex Object Instance Service is a business service that is available for accessing the Instance API.
Note: For more information on debugging the Configurator APIs, see see 2037936.1 (Doc ID) on My Oracle Support.
