Defining Promotion Eligibility Rules
This procedure describes how to define eligibility rules for product promotions.
To define promotion eligibility rules
Navigate to the Administration - Product screen.
In the link bar, select Product Promotions.
In the Product Promotions list, select the promotion you are defining rules for.
Click the Eligibility and Compatibility Rules view tab.
In the link bar of the Eligibility and Compatibility Rules view, click Eligibility.
Add records to the eligibility rules list and enter criteria in the same way that you do when you are defining product eligibility rules.
