Delete Contents of ISS_OBrkCache Directory
You must delete the contents of this directory. This makes sure that the application loads your changes when generating a customizable product, rather than loading the objects from the cache directory.
To delete the contents of the ISS_OBrkCache directory
  1. Locate the Siebel File System directory.
    To see the directory path or system name for the directory, from the Siebel application Help menu, choose Technical Support.
  2. In the Siebel File System directory, locate the ISS_OBrkCache directory.
  3. Delete all the files in the ISS_OBrkCache directory.
