Deleting Products from Products with Components
You can only delete products from the current work space of a customizable product. You cannot delete products from a released version. You can delete relationships or products included within a relationship.
Changes are not propagated to other parts of the product with components. For example, if you delete a product from a relationship, configuration rules for that product are not deleted.
If you delete a product from a relationship that has domain type Dynamic Class, the product will be added back to the relationship when you refresh the work space or release the product. This is because the product still exists in the product class. When you refresh the work space or release the product, the relationship is updated so that it contains all the products in the product class and the current attribute definitions.
To avoid this, you can change the relationship domain type to Class. This breaks the connection to the product class system and prevents any further updates of the relationship. You can also leave the domain type unchanged and remove the product from the product class.
To delete products
  1. Navigate to the Administration - Product screen, then the Product Definitions view.
  2. In the Products list, select and lock the desired product with components.
  3. In the Versions list, click the Work Space version.
  4. To delete a relationship, select the desired relationship record. To delete a product within relationship, expand the relationship and select the product record.
  5. From the Structure menu, choose Delete Record.
  6. Revise configuration rules, link definitions, and resource definitions as needed.
