Error Messages for Quick Edit
If a sales agent adds several components that are not validated individually and then clicks the Turn Off Quick Edit button, the Siebel Product Configurator might display error messages:
If the components are compatible and the configuration is valid, no message is displayed.
If a required component is missing and the configuration is incomplete, Siebel Product Configurator adds missing products to create a valid configuration and displays a message in the Messages box saying which products are added by the engine.
If incompatible components are added, Siebel Product Configurator displays a conflict message and the user has two options:
Click Undo to go back to the previous page and correct the error.
Click Proceed. Siebel Product Configurator might display one incompatible product in red or might remove one incompatible product.
