GetConditionVal Method
This method allows users to call and retrieve the values of the named expression variables.
Input Arguments
CondName. The name of the condition variable.
IntId. The integration id of the product.
Output Arguments
If the condition variable is found and evaluates to true, the property Result is set to Y in the output arguments. If not, the Result is set to N.
For example, define a Product as follows:
Class1
-> Att1
Product: Child1 (associated with Class1)
Attribute: Att1 (which has the default value of one)
Constraints List:
Constraint: The attribute SekAtt1 = one sets the value of the procedural condition variable to true
Product: Root (associated with Class1)
Re1: Child1
You can use the following script:
function Cfg_AttributeChanged (ChangedAttribute)
var Service = TheApplication().GetService("Configurator Service");
var Variable ="RuleOne";
var VariableVal = "";
var IntegrationID= AddItem("$.[Root]#1", "R1", "Child1", "1")
var InputArgs = TheApplication().NewPropertySet();
var OutputArgs = TheApplication().NewPropertySet();
InputArgs.SetProperty("CondName", Variable);
InputArgs.SetProperty("IntId", IntegrationID);
Service.InvokeMethod("GetConditionVal", InputArgs, OutputArgs);
Variable = OutputArgs.GetProperty("Result");
if (Variable == "Y")
TheApplication().RaiseErrorText("True" );
else
TheApplication().RaiseErrorText("False" );
