GetProdStruct Method
This method returns the full structure of the customizable product.
Input Arguments
  • RootId. The unique identifier of the complex object root. If provided, RootName, Vendor, and Org are ignored. If not provided, RootName, Vendor, and Org are used to uniquely identify the product.
  • RootName. The root product name. Optionally, you can use Name together with Vendor and Org to uniquely identify a product.
  • (Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version. Specify 0 to return the work space.
  • (Optional) Vendor. Use with RootName to uniquely identify the product. By default, this is empty.
  • (Optional) Org. Use with RootName to uniquely identify the product. By default, this is empty.
  • Full. Y returns the full product structure. N returns the first level of the product.
Output Arguments
The output is in Property Set format.
 <ProdStruct> RootId
    <ProdId> Name ClassId
       <Port> Name ClassName ClassId OrigId Type MinCard MaxCard DefltCard LocalType
InternalType
          <Subobject Id/>
       </port>
       <Attribute> Name
          <Domain Value />
       </Attribute>
    </ProdId>
 </ProdStruct>
