Guidelines for Using the Grid Layout Group Theme
Observe the following guidelines when using the Grid Layout Group Theme:
The Grid layout feature is not supported for multi-level grandchild control templates, which recursively includes the group theme to show a grid table inside of another grid table.
The grid layout theme should be used judiciously. The performance of the Siebel Product Configurator UI degrades with the number of controls displayed within the page.
The grid layout theme can be used to control the display of all types of controls in the interface, including controls based on fields, relationships, attributes, linked items and resources.
The following UI Control templates can be used with the Grid layout Group Theme.
With the Web template JS (RELATIONSHIP):
Check Box GridLayout JS (eCfgControlCheckGridLayoutJS)
Radio Buttons GridLayout JS (CfgControlRadioGridLayoutJS)
Combo Box with Price Attribute Grid JS (eCfgControlComboAddPriceAttribGridJS)
With the Web template JS (ATTRIBUTES):
- Radio Button GridLayout for Attribute JS (eCfgAttributeRadioGridLayoutJS.)
Note: If these templates are not available within the UI Control pick applet, then manually create a record in the pick applet and map it to the appropriate Web template files.
