Pricing and Eligibility Procedure - Default Workflow
Pricing and Eligibility Procedure - Default workflow will check the Eligibility and Compatibility of a Line Item and then do Pricing.
This workflow is shown in the following figure.
The Pricing and Eligibility Procedure - Default workflow is described in the surrounding text.
Workflow Description
This workflow does the following:
  • Product E + C. Calls the Check Eligibility & Compatibility - Default workflow, which checks eligibility and compatibility for the Line Items.
  • Pricing. Calls the Pricing Procedure - Default workflow, which prices the line items.
