ReplaceItem Method
This method replaces an existing item with the new item on a specified port, removing the existing item from the port and creating a new instance for new item.
Input Arguments
  • ObjId. The unique identifier of the complex object header.
  • RootId. The unique identifier of the complex object root.
  • (Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
  • Path. Integration Id of the existing product (which is going to be replaced by new product)
  • Name. The name of the new item.
  • Product Id. The new product id in S_PROD_INT table.
  • Prod Item Id. The ID of the new item (for example, ORIG_ID in S_PROD_ITEM table).
  • Port Item Id. The ID of the item's port (for example, ORIG_ID of the port in S_PROD_ITEM table).
  • Quantity. The new item quantity.
  • (Optional) AutoResolve. Automatically resolves port cardinality violations. The default is N.
  • (Optional) List Price. The item list price from Pricing Manager, which can be empty.
  • (Optional) Current Price. The current price from Pricing Manager, which can be empty.
  • (Optional) Parent Path. Integration Id of the parent item the port belongs to.
  • (Optional) Parent Display Name. Display name of the parent product. This parameter and the display parameters that follow would be used in logging error messages in case of error.
  • (Optional) New Child Display Name. Display name of the new child product.
  • (Optional) Port Display Name. Display name of the Relationship of the child product.
Output Arguments
None.
