Configuring Case Categories for Appeal Cases
In the preconfigured Siebel Public Sector application, the Appeal button is enabled only for cases that have a Category field of Benefit. Administrators can enable this button for additional case categories.
This task is a step in Process of Configuring Appeal Cases.
To configure the case categories for appeal cases
Log in to Siebel Tools or Web Tools as an administrator and create a new workspace.
Select Business Component in the Object Explorer, and then select the HLS Case business component.
Lock this business component so that you can change it.
Navigate to Business Component, then Field in the Object Explorer.
In the Calculated Value column of the CanAppealCategories field, change the value to the following text:
IIF(([Category]=LookupValue("PUB_CASE_CATEGORY_TYPE","Benefit")) OR ([Category]=LookupValue("PUB_CASE_CATEGORY_TYPE","New_Category")) OR ([Category]=LookupValue("PUB_CASE_CATEGORY_TYPE","New_Category")) OR ([Category]=LookupValue("PUB_CASE_CATEGORY_TYPE","New_Category")),"Y","N")In this text, New_Category is the value for the Category field of the case. You can designate any number of Category field values.
Note: The preconfigured value for the Calculated Value column of the CanAppealCategories field isIIF([Category]=LookupValue("PUB_CASE_CATEGORY_TYPE","Benefit"),"Y","N").Deliver the changes to the Integration Branch.
Unlock the business component.
