Modifying the Routing Group for a Regional Node
You can modify the routing group for the Siebel Server of a regional node. For more information, see How Siebel Replication Manager Uses Routing Groups.
To modify the routing group for a regional node
If the regional node contains remote clients, then synchronize these clients with the regional node.
Send updates that exist in the regional node to the headquarters or parent node.
Stop any update activity on the regional node.
Locate the record for the regional database where you must modify the routing group.
The correct node for the parent in the Parent Server form is typically HQ. For more information, see Locating the Record for the Regional Database.
In the Routing Group field, click the select icon.
In the Pick Routing Model dialog box, choose the new Routing Group, and then click OK.
Caution: For important caution information about modifying the routing group from Standard to Full Copy, see Requirements for Extracting the Server Database.Extract the regional database.
For more information, see Extracting the Regional Database.
Initialize the regional database.
For more information, see Initializing the Regional Database.
Extract the Siebel database for each remote client that exists on the new regional node.
For more information, see Extracting the Server Database.
Resume operations on the regional node.
