Querying for Orphan Records
To examine orphan records in the Siebel database, you can use an SQL query. This query locates rows in the S_DOC_TXN_LOG table that meet any of the following conditions:
  • Row ID is not equal to the parent transaction ID
  • The parent transaction ID does not equal the row ID of any other row in the table
To query for orphan records
  1. Query for the orphaned records:
    • To query in Oracle Database, use the following command:
      SELECT B.TXN_ID, B.ROW_ID, B.PAR_TXN_ID, B.OPERATION, B.ITEM_NAME FROM
      S_DOCK_TXN_LOG A, S_DOCK_TXN_LOG B WHERE A.ROW_ID(+) = B.PAR_TXN_ID AND
      A.ROW_ID IS NULL
    • To query in IBM DB2 or Microsoft SQL Server, use the following command:
      S_DOCK_TXN_LOG A RIGHT OUTER JOIN S_DOCK_TXN_LOG B ON B.PAR_TXN_ID = A.ROW_ID
      WHERE A.ROW_ID IS NULL
  2. If you find a gap in transaction ID numbers, then use the Txnskip utility.
    An orphan record does not necessarily cause a gap in transaction ID numbers. For situations where you find a gap, you can use the Txnskip utility instead of the Endtxnutl utility. For more information, see Using the Txnskip Utility to Examine Skipped Transactions.
