Requirements for Remote Clients
The following requirements are mandatory for the remote client:
  • Each remote client must use exactly one local database at any one time.
  • Only one user can access the local database at any one time. Siebel Remote does not support multiple logins.
  • You must not rename any folder that contains software for the remote client.
  • You must not rename or delete any DX file.
  • You must not directly modify the local transaction log under any circumstances.
Caution: Never directly modify the local transaction log. The Synchronization Client automatically removes all entries from the local transaction log table.
To optimize performance, it is recommended that the user defragment the local hard drive regularly. For more information, see the defragment policies for your company.
