Configuring TLS Encryption for Siebel Application Interface
This topic describes how to configure the Siebel Application Interface to use TLS encryption and, optionally, authentication for communications with Siebel Servers. Configuring TLS communications between Siebel Servers and the Web server also requires that you configure a Siebel Enterprise or Siebel Server to use TLS. For information on this task, see Configuring TLS Encryption for Siebel Enterprise or Siebel Server.
This task is a step in Process of Configuring Secure Communications.
You must include TLS-related parameters in the applicationinterface.properties file if you are using TLS to encrypt communications between the Web server and the Siebel Server.
To configure TLS encryption for Siebel Application Interface
Ensure that the following parameters are set in the applicationinterface.properties file by the Siebel installer:
TrustStoreName
KeyStoreName
TrustStorePassword
TrustStoreType=JKS
KeystoreType=JKS
KeyStore and TrustStore with valid certificate, are a prerequisite for the application interface component installer to pick and use.
The applicationinterface.properties file is located on the Siebel Application Interface in the
applicationcontainer_external\webappsfolder.In addition to these parameters, set the following parameter in the setenv.bat file located on the Siebel Application Interface in the
applicationcontainer_external\binfolder:set CATALINA_OPTS=-Djavax.net.ssl.keyStoreAlias=<<keystore alias name>>
