Parameters for Enterprise, Siebel Servers, or Components
This topic describes the security adapter parameters you can set at the Siebel Gateway level, at the Enterprise level, at the Siebel Server level, or at the component level. Applicable components for which you can set these parameters include all Application Object Manager components and the Synchronization Manager component (for Siebel Remote).
To implement LDAP authentication for a single Siebel application, set the parameters for the applicable Application Object Manager component, such as for Siebel Call Center or Siebel eService, using values similar to those shown in the following table.
Subsystem
Parameter
Guideline
Security Manager
SecAdptMode
For more information about setting this parameter, see the Enterprise Security Authentication Profile (Security Adapter Mode) parameter in the table in Parameters for Configuring Security Adapter Authentication.
The security adapter mode in which to operate. For LDAP, specify LDAP.
Security Manager
SecAdptName
For more information about setting this parameter, see the Security Adapter Name (named subsystem) parameter in the table in Parameters for Configuring Security Adapter Authentication.
The name of the security adapter. For LDAP, specify LDAPSecAdpt or another name of your choice.
The name represents the alias for the enterprise profile (named subsystem) for the specified security adapter.
