Setting Up Responsibilities and Adding Views and Users
This topic describes how to set up responsibilities and add views and users.
To define a responsibility and add views and users
  1. Navigate to the Administration - Application screen, then the Responsibilities view.
    The Responsibilities view appears.
    Note: By default, the Responsibilities view shows all responsibilities, regardless of organization. However, you might want to configure new views in Siebel Tools that restrict the visibility to responsibilities. For more information on configuring views, see Configuring Siebel Business Applications.
  2. In the Responsibilities list, add a new record and enter a name and description for the responsibility.
  3. In the Organization field, select an organization for the responsibility.
  4. To add views, do the following:
    1. In the Views list, add a new record.
    2. Select the appropriate views in the Add Views dialog box and click OK.
    When you add a view, set the flag Read Only View if users with this responsibility only require read access to the view.
    Note: You can also delete views from the Views list.
  5. To add users, do the following:
    1. In the Users list, add a new record.
    2. Select the appropriate users in the Add Users dialog box and click OK.
    Note: You can also delete employees from the Users list.
Related Topic
About View and Data Access Control
