Arguments for Set Work Item Attributes Method
The following information lists the arguments for the Set Work Item Attributes method.
Note: For this method, you can set values for one or more attributes
for the work item, using key-value pairs rather than arguments with
fixed names. (By contrast, the methods Get Inbound Work Item Attributes
and Get Work Item Attributes use the Attribute Name and Attribute
Value arguments to store the name of a single attribute to retrieve,
and its value, respectively.)
| Argument Display Name And Data Type | Argument Name | Type | Req’d | Comment |
Work Item ID (type: String) |
WorkItemID |
Input |
Yes |
Work item ID |
