Arguments for Work Item Started Method
The following table lists the arguments for the Work Item Started method.
| Argument Display Name And Data Type | Argument Name | Type | Req’d | Comment |
Channel Profile (type: String) |
MediaProfile |
Input |
Yes |
Name of driver profile that owns this work item |
Channel Type (type: String) |
MediaType |
Input |
Yes |
Language-independent value of the channel type |
Description (type: String) |
Description |
Input |
Yes |
Work item description |
Object ID (type: String) |
ObjectID |
Input |
Yes |
Object ID of work item |
Old Work Item ID (type: String) |
OldWorkItemID |
Input |
Yes |
Old work item ID |
Start Time (type: Number) |
StartTime |
Input |
Yes |
Time work item is started |
WorkItemID |
Input |
Yes |
Work item ID |
