Managing Temporary Disk Space Required by Siebel Installers and Wizards
This task is part of Planning Your Siebel Deployment.
The Siebel CRM installer and other programs all require the use of temporary disk space while operating. Disk space required varies by operating system. The location of temporary directories is specified using the TEMP and TMP environment variables. Set these variables the same: to a valid existing directory that contains adequate space.
It is recommended that you periodically clear out the temporary directory that you are using. You might have to do this as part of resolving installer or wizard problems.
On Microsoft Windows, the temporary directory used by default is C:\Documents and Settings\username\Local Settings\Temp
The minimum disk space figures provided in this topic are general guidelines only. The specific amount of temporary disk space needed by a particular installation operation varies. If there is insufficient disk space, then the installer will notify you that more disk space is needed.
The user running the installer or wizard must have privileges that include write permission for the temporary directory.
The following shows the minimum disk space required by Siebel installers and wizards (by operating system), along with the default temporary directory locations.
Operating System | Minimum Required Space | Default Location |
Windows |
65 to 100 MB |
System drive (usually |
AIX |
200 MB |
HP-UX |
240 MB |
Linux |
200 MB |
Home directory for user |
Oracle Solaris |
115 MB |
To verify the name of your temporary directory
From a DOS command prompt, enter the commands
set temp
andset tmp
